Topic: M-1620 Pro D Dante Tx signal indicator
I have 28 devices on my Dante network and the only one not to show the transmit signal indicator on the Transmit page of Dante Controller is the RME M-1620 Pro D, is there a way to turn on this functionality that I've overlooked? If not, is it something that could be implemented in a future update as I find it quite useful for quick troubleshooting?
Re: M-1620 Pro D Dante Tx signal indicator
this is a known issue and will be fixed with the next firmware release.
Best regards
Marc
Appreciate the swift reply, thanks.
One other thing I noticed that may be specific to the situation but I don’t see how, if you set the M‑1620 as the preferred leader in Dante Controller, the setting doesn’t persist after a reboot. It only seems to remain if you set the preferred leader directly on the unit itself.
Thanks again.
