Topic: Auto-show TotalMix window when using the ARC controller?
Hello!
I’m not sure if this is possible, but I couldn’t find any way to do it.
Is there a way to automatically display the TotalMix window whenever I touch a control (press a button, adjust the volume, etc) on the ARC controller?
I understand that you can set up a button to toggle the TotalMix window, but it would be much more convenient if this could be done automatically every time I use the ARC controller. The window could then hide again after a few seconds.
