Topic: can i use digicheck to look at wav file to analyze bits?
seems this should be a basic feature but load wave file is greyed out.
How do i do it?
per usual the rme docs arent of any help
Re: can i use digicheck to look at wav file to analyze bits?
Hello Jerry
As usual someone starts to report about an issue without telling details.
What software are you talking ?
Digicheck NG on Mac ?
Windows ?
Digicheck version number ?
I don't have a feature load wave file, here on Digicheck NG on Mac, maybe this is a Windows exclusive feature ?
3 (edited by ramses 2026-08-08 00:15:37)
Then you are using the older version of DIGICheck (5.x) under Windows.
Reason: only the Windows version of DIGICheck has Global Record, which is required for loading a Wave File.
Why do you complain about the documentation? The online help clearly provides you this information:
Load Wave File: "Dieser Menüpunkt öffnet eine Dialogbox zur Auswahl eines Wave Files welches in die Funktion Global Record geladen wird. In den anderen Funktionen ist dieser Menüpunkt ausgegraut. Entspricht der Taste Load in der Transportleiste."
There is no graphical waveform display or editor. Please use external audio software like Reaper or similar.
V5.96
so its not an option, only on playback through a device?
6 (edited by ramses 2026-08-08 08:28:57)
jerryfreak wrote:
V5.96
It's a tool that works in near real-time, so you need the time component -> playback.
As examples: my workspaces for playback of music using the MusicBee player
HDSPe MADI FX (PCIe card), Channel -> SW Playback for the Phones Channel.
DIGICheck 5.96
https://www.dropbox.com/scl/fi/6744crso … 3&dl=1
https://www.dropbox.com/scl/fi/6744crso6cdz0tv9cew9e/2026-08-08-DIGICheck-5.x-My-Workspace.jpg?rlkey=lohgpukvhysfz75zz5w53d9qt&st=yl81whx3&dl=1
DIGICheck 5.96 - One example of Input Device Setup (you have to configure it for every DIGICheck window)
https://www.dropbox.com/scl/fi/pipu1y9r … x&dl=1
https://www.dropbox.com/scl/fi/pipu1y9rnz24w4rqzghiy/2026-08-08-DIGICheck-5.x-Input-Device-Setup.jpg?rlkey=zsfcyd6hgg0zzh6zt9f2davnj&st=mqbtnjyx&dl=1
DIGICheck NG 0.93
https://www.dropbox.com/scl/fi/wqtzawb7 … 4&dl=1
https://www.dropbox.com/scl/fi/wqtzawb7jlv5xz4namug2/2026-08-08-DIGICheck-NG-My-Workspace.jpg?rlkey=595uscnbte7tnfp5p8a9lkbn3&st=v6ifyom4&dl=1
DIGICheck NG 0.93 - One example of Input Device Setup (you have to configure it for every DIGICheck window)
https://www.dropbox.com/scl/fi/5rahxb8n … n&dl=1
https://www.dropbox.com/scl/fi/5rahxb8nczygx62nj97ki/2026-08-08-DIGICheck-NG-Input-Device-Setup.jpg?rlkey=ww4iq6oy0akgsk390ko1vppq3&st=h8s1g6gn&dl=1
7 (edited by ramses 2026-08-08 08:35:27)
I just tried the loading of wave file
I opened the DC 5.x "Global Record" window, where you can load a .wav file.
I opened the Totalyser Window for analyzing the wave file, but it can by any other analyzer window, one or multiple.
In the Global Record Window you need to select the proper RME ASIO driver, Device and as Source: Playback.
Select two (stereo) channels, using the record arm buttons (see the red button in the screenshot).
This is where the audio will be played back in the middle row = SW Playbacks = Audio coming from the computer.
I am sending it to the PH L and PH R channel because this is where I usually have sound from MusicBee,
and those channels are routed to my standard monitoring through the HW output AES.
On this particular HW Output you need to enable Loopback.
In my case to get the playback of this wave file on the corresponding HW input AES IN.
Now open the input settings of the Digicheck Totalyser (or any other DC analyzer window).
There you need to select the Input Channel AES IN, where you get the audio stream through loopback.
Why loopback in this case? SW Playback is already in use by Global Record to load/playback the wave file.
Through loopback recording, we can redirect audio to an HW input.
And from there we can read the audio stream with any DC analyzer window.
Global Record - Select driver, playback and arm the two playback channels in the application
https://www.dropbox.com/scl/fi/b6gh4fe6pv7a6cb77asvy/2026-08-08-DIGICheck-5.x-Input-Device-Setup-and-Selection-of-SW-Playback-Channel.jpg?rlkey=e884oo9rzynr7k7zvp5yi0xac&st=moab2pj0&dl=1
Global Record - Start playback - SW playback PH is routed in TotalMix FX to HW Output AES (with loopback enabled)
https://www.dropbox.com/scl/fi/qo8iuitbn0sjvgbelkvx9/2026-08-08-DIGICheck-5.x-Loading-Wave-File.jpg?rlkey=1e1kulttu4ngep3awg900b2ic&st=865d420t&dl=1
Analyser - Select the proper input channel HW Input AES, this channel gets audio through loopback
https://www.dropbox.com/scl/fi/9viaai0oc46tz33zvybmh/2026-08-08-DIGICheck-5.x-Input-Device-Setup-Loopback-Channel-for-DC-Analyzers.jpg?rlkey=e6wb11evmqqcx7ifve9qg31g8&st=wyav9yka&dl=1
Finally..
The Load Wavefile function in the older DC 5.96 needs the DIGICheck "Global Record" window, BUT ...
... at the end of the day you can use any Windows Audio Player or DAW or WaveLAB etc to play a wav file
and to analyse the audio data through either DIGICheck 5.96 or the newer - more modern - DIGICheck NG.
wow, so it is possible, albeit cumbersome
As I mentioned, do not make it so hard for you ... you do not need this.
Play music through your audio application and monitor the playback channel. It's the same and easier to handle.
10 (edited by waedi 2026-08-08 12:20:07)
To find out the bit-depth of a wave file on a Windows computer you simply can use VLC player.
Open the file and press Control-J
See the codec informations for this file.
