Topic: SOLVED - Troubles with TotalMix 2
Recently I bought a new UCX II, installed its driver, and after that, the driver for TotalMix 2. Troubles started immediately.
Upon opening, two (!) TotalMixes appeared, and with them two identical information-messages:
Mismatch detected - mixer state of
Fireface UCX II (1) and TotalMix FX are different.
Click "TotalMix" to use the TotalMix settings (default) or
Click "Device" to convert the Device' mix into a TotalMix FX
mixer state or
Note: If unsure, click "Device" to check the unit's settings first,
then hit Undo to restore the last TotalMix FX settings
Device TotalMix
This was incomprehensible and very frustrating to me, and after a long hours of trying to make it work, it settled (as normal one TM), and I imported whole bunch of settings in it... But the next day, after turning up UCX & TotalMix, that "normal" version disappeared, and there was just one, "other one" which couldn't read almost any of my previous settings, and in the top left side it was text:
RME TotalMix FX: Fireface UCX II (1) - disconnected
To make things even worse, I cannot uninstall it! I thought I should try to re-install the driver, but there is no file to uninstall!!!
I'm using Windows 10 PC, which doesn't make any problems.
My previous device was Babyface Pro FS, and I uninstalled the driver before installing the new one, for UCX II.
Please help!
