Topic: HDSPe AES Rev.1 and AVID S6L audio glitches
I own 2 HDSPe interface that i use with an OWC Helios3 PCIe Thunderbolt 3 enclosure :
AIO with breakout XLR Cable and
AES Rev.1 with Tascam DB25 XLR breakout cable
I do external vocal processing in a MacMini M2 LiveProfessor VST plugin Host with the AIO, inserted on 2 different channels of an Avid S6L Mixing Console :
RME AES Out 1 -> S6L AES In 1 (ins. Return)
RME AES Out 2 -> S6L AES In2 (ins. Return)
S6L AES Out 1 (Ins. Send) -> RME AES In 1
S6L AES Out 2 (Ins. Send) -> RME AES In 2
The VST Host MacMini project is running @48K / RME AIO @48k
The Avid S6L is running @96khz
Everything is working flawlessly.
But if i swap from HDSPe AIO card to HDSPe AES card w/ db25 to try the same project i got random ugly audio glitches/artefacts/distortion on both inputs/outputs.
I tried to change the "double wire" stuff, i tried to change XLR in/out AND VST Host in/out but i'm really struggling to understand where goes the signal in which XLR in this type of configuration and how to get rid of the glitches.
I was thinking that the SRC would be as OK with the AES card than the AIO but i may be wrong or incorrect.
Any help would be much appreciated ![]()
