1 (edited by terrys999 2026-08-17 23:18:05)
Topic: [Solved] Adi 2 pro ex headphones Not muting dsd
Hi all.
Just noticed that if I plug headphones in playing dsd direct dsd. The headphones are not auto muting?
Why??
Also if i turn off direct dsd nothing changes still shows dsd. There should be a click.
Firmware fully updated.
Hermmmm
I have adi 2/4 pro and adi 2 dac fs akm they work fine.
Is it firmware problem or is my unit buggered.
Only had it 2 days.
So to recap
Headphones won't mute playing dsd.
Turning off direct dsd does nothing. Dsd detection works..
Need to know if its firmware related or a damaged unit.
I have done multiple resets still same.
Will wait for a firmware then if not its going back.
Update...
The manual states that headphones will be muted in balanced mode.
So I take it that unbalanced will still be active.
And yet dsd on adi 2 dac fs akm in direct dsd mutes headphones. HELP!!!
Re: [Solved] Adi 2 pro ex headphones Not muting dsd
Don't worry, ADI-2 Pro EX just arrived.
No wonder there might be little hiccups here and there, and DSD has its specialties.
RME is known for fixing stuff fast once something turns up.
3
The Phones channels 3/4 always run in DSD Direct mode Off, so always work. DAC channels 1/2 Line and 1/2 Phones do use DSD Direct and therefore switch off when DSD Direct is set to On.
This is the current state for all ADI-2 Pro. I also don't get where the confusion comes from, as this is clearly described in the Pro's manual:
After having activated DSD Direct in the ADI-2 Pro’s menu (SETUP - Options - Device Mode / DSD - DSD Direct 1/2), channels 1/2 use this mode when a DSD signal is received. The analog signal is then available at the rear outputs, with a coarse volume control via the analog output reference level control. Outputs PH 1/2 are deactivated. Outputs PH 3/4 stay in normal DSD mode and have the standard volume control available.
Note that the option clearly says 'DSD Direct 1/2' !
Ohhh yes thank you.
My head was all over the place i should have read manual .
5
In fact I don't expect any new 'bugs' to show up as the ADI-2 Pro EX is built on the mature ADI-2 Pro series firmware. On the contrary its firmware includes several fixes for never reported issues, reported issues and wishes. One example: Crossfeed is now pre EQ. Some of these (as Crossfeed pre EQ) have already been back-ported to all ADI-2 Pro models (FS, FS R BE, AE...) in latest firmware FPGA 269 DSP 130, others will follow later. More details about this will be released on a later date. We couldn't add them to the firmware readme yet to not disclose EX series stuff too early, sorry.
