Topic: remember presets for eq and dyn
How hard would it be for RME to add a feature to TotalMix FX so that you can tell which eq preset you have loaded? Yes, I can write down the preset after I load it and can take screenshots and so on, but that's awfully cumbersome when in a better world you could just right click on your eq and have it tell you which preset you are in
Same for dynamics presets.  This is one of my only complaints
Re: remember presets for eq and dyn
+1 good idea.
I just had a look how it might look.
There is room between EQ and the pulldown menu on the right.
Depending on the font it offers room for up to 15 chars.
Maybe only 13 so that it doesn't look too overloaded, the rest of the name could be truncated.
Another possibility might be, if possible, to show the active preset in boldface in the dropdown menu.
https://www.dropbox.com/scl/fi/imbxwr3l … o&dl=1
https://www.dropbox.com/scl/fi/imbxwr3lzfpnq1pbp0u86/2026-08-26-TM-FX-Preset-Display.jpg?rlkey=g50kh5svxbepk8m9dj5pxnozh&st=k4z31ilo&dl=1
3 (edited by tom_schultz 2026-08-26 13:16:50)
Highlighting the preset you are in looks great.  If only they could add that in the next version.  Thanks
But there is "small" problem. If one changes value later, it will be ex-preset. And other way round, if one changes preset later on, it will not be reflected in fader settings....
Still, it would be handy if there is indication, on which preset are the values based.
Like with the ADI-2 Remote, the name could change then to "Manual" or "Temp".
