Topic: DTOX-16: Fastener Specs?
The official documentation for the DTOX-16 does not include specifications for the fasteners used to hold the panels together or the rack ears on. I'm running it un-racked with the rack ears uninstalled using some adhesive sorbothane feet. Unfortunately, the screw holes used to hold the ears on appear to go all the way through the outer case, so when the ears and screws are removed, the interior is no longer sealed. I can reinstall the included screws, but they are countersunk into the ears, so they look awkward when screwed into the bare panel. Therefore, I'd like to order some replacement panhead screws that will sit properly against the panel surface. Does anybody know the diameter, thread spacing, and thread pitch for the rack ear screws?
