Topic: multiface (multiset) heat glitch issue?
I've got an ancient multiface (actually, Nuendo-branded "multiset"). It's literally coming up on a quarter century old. I have noticed at times I get a small amount of random audio glitching, which sometimes grows in frequency and intensity to the point where audio played out of Cubase is almost unrecognizable.
Another symptom is that, sometimes, the glitching gets bad and the computer itself gets slower and slower, to where mouse movements take seconds to minutes to register.
Also seemingly correlated, if I shut everything down, put an ice pack on top of the Multiface until it gets notably cold, then restart everything, I can generally work glitch-free, at least for a good while.
My initial impression is that this seems to correlate with warmer room temperatures, and/or longer times on and working.
Is this a known failure symptom of something Multiface-related?
The unit is mounted in open air on a pair of arms. So it has free air on all sides. I have also run it with a fan blowing directly on it, but that in itself (without the ice pack) doesn't always help.
The problem is intermittent, so it's hard to reliably reproduce/test.
Windows 10
Cubase 14
Does this ring any bells? When the unit is working, it still works beautifully. In warm weather, it seems to be a crapshoot.
Thanks...
