1 (edited by magnumpraw 2026-10-13 20:51:24)
Topic: MIDI control for buttons not working?
I am setting up my Korg NanoKontrol to control several things in TotalMix.
I have been successful getting the faders to control the faders I want in TotalMix, but am having trouble getting the buttons to do anything to TotalMix buttons, I have tried Talkback, Dim, and Snapshots without any luck.
I know midi is getting to TotalMix from the NanoKontrol, because the faders are working properly.
Here is a screenshot from Protokol showing a fader message and a button message. The fader is correctly moving the fader in TotalMix, but the button press should be activating Talkback, but nothing happens.
Any ideas where I'm going wrong?
(sorry not sure how to get images to show up here)
https://www.dropbox.com/scl/fi/kl783bie … j&dl=0
https://www.dropbox.com/scl/fi/kl783biee4644qz79p0h0/Screenshot-2026-10-08-at-10.14.19-PM.png?rlkey=z3oigmeu8elklscoxqnads54j&dl=0
2 (edited by waedi 2026-10-09 08:05:50)
Re: MIDI control for buttons not working?
For the screenshots :
You have to upload the screenshot to the internet (public internet).
Your google drive needs login approval, it's not public.
I use free public image service imgbb.com
Upload the image and it returns a link.
Open the link in your browser,
right-click the image,
copy image address,
paste image address between img tags in the forum post.
Using Dropbox might have some advantages:
https://www.tonstudio-forum.de/blog/Ent … rum-EN-DE/
BR Ramses - HDSPe MADI FX, M-1620 Pro D, 12Mic, UFX III, ADI-2/4 Pro EX, Nuendo15, Win10 IoT Ent.
4 (edited by magnumpraw 2026-10-13 20:54:53)
yeah, should've used dropbox to begin with.
I've updated the links in the original post with this
use note on with vel 0/127 to toggle TB. Instead note off with vel 64 as your touchosc log shows.
hex: 90 5E 00/7F
“Do It For Her”
I am sending a note ON message on Channel 1 for note 94 with velocity of 127.
(see the 2nd to last line)
It's not affecting Total Mix in anyway.
but not a 94 with vel 0...
“Do It For Her”
8 (edited by magnumpraw 2026-10-27 19:07:50)
unfortunately the Nano Control does not allow for a Note Off value to be specified. It seems Note Off value is always 64.
also, the Note On value is limited to 1-127. There is no option for 0.
That said, I have tried setting Note On to 127 and to 1. Neither did anything in TotalMix.
Even if the Note Off value can't be set to 0, shouldn't the talk back at least turn on when receiving note 94 at 127. (It just wouldn't turn off, right?)
Problem Solved.
I did not have the Mackie Control Protocol engaged.
after enabling the MC Protocol Support, buttons are working
10
As that is on by default the question would be why did you turn it off...
I've had it set that way for years. I think I originally switched it off cause I'm not using fader banking and didn't want to see the first 8 channels in yellow.
