Topic: Using ADAT - Fireface or Babyface ?
I would like to know, when I just use ADAT, if Fireface (400, UC, UCX) are better than Babyface (1st, Pro, Pro FS) ?
Or if it's the same for all ?
My setup is :
Préamps (various) -> ADI-8 Converter -> (ADAT) -> Babyface or Fireface (?)
Thanks !
Re: Using ADAT - Fireface or Babyface ?
No difference at all....
Thank you very much !
And just out of curiosity, my setup works fine :
But if I would like to make an update, is there a anything better that you could recommand ?
No, only better converters would improve things, but only on paper, not audible. Really you are fine!
If you want to spend money, spend it on monitors, headphones, mics and accoustic teatment or new instruments or learn new skills. In the converter/audio interface section you are set for life (or till something breaks).
5 (edited by ramses 2026-10-14 16:24:50)
A recording interface doesn't just consist of its ADAT I/O.
If the rest doesn't matter, you might be better off buying a Digiface USB, or RayDAT (if PCIe would be an option) new.
FireWire would be the last thing where I would invest money into.
If instruments are needed, I would look for those models which have 1 MOhm impedance like Babyface Pro [FS].
Also, their headphones output support 10/2 Ohm, which is a little better compared to 30 ohm outputs.
If you want mic inputs with a little higher gain range, then loot at: UC, UCX and Babyface Pro [FS].
If you want to have faster converters look at: UCX, Babyface Pro FS
Have a look at my interface comparison Excel:
https://forum.rme-audio.de/viewtopic.php?id=35156
BR Ramses - HDSPe MADI FX, M-1620 Pro D, 12Mic, UFX III, ADI-2/4 Pro EX, Nuendo15, Win10 IoT Ent.
6 (edited by Kubrak 2026-10-14 16:59:56)
zup wrote:
Fireface (400, UC, UCX) vs. Babyfaces - ADAT
The main/only difference is that Fireface 400 does not have USB, just Firewire...
Ramses is right, that if ADAT is your only request, you might also consider Digiface USB (secondhand it costs about the same as FF UC, or even less and less than FF UCX or secondhand Babyface Pro/Pro fs), or RayDat.
You would have four times more ADATs. Mind, if that matters, that Digiface USB cannot work standalone and that FF UC and DF USB do not have effect section and BF Pro fs only limited set of effects. FF 400 and BF 1. gen/BF Pro I do not know.
Thank you both for your replies !!!
I already have good mics, preamps, monitors and headphones... I think I'll just upgrade my old Babyface (1st generation) to a Pro or Pro FS...
Thanks !!!
Ah ok... I didn't understood, A Digiface instead of the Babyface ?
In deed, it's a good idea, but I like the Babyface because sometimes I need a nomade interface out of the studio.
So that was also my doubt : Have an interface with ADAT (in studio) and if I need to use it with 2 inputs (out of studio).
I like the Babyface but for the inputs maybe it's better the Fireface (UC or UCX)...
No other interface's ADAT inputs are somehow better than those of the Babyface. The only reasons for a Digiface USB would be using sample rates of more than 48k or more than 8 channels (with another converter). Otherwise, no need to change.
Ok !
It's noe the case for me so... I keep the Babyface
Maybe buy a Fireface (UC, UCX) if preamps of inputs are better...
11 (edited by ramses 2026-10-14 20:06:30)
It’s surely obvious that ADAT connections are all the same. After all, most of the time you use a bit more of the interface than just the ADAT port.
Given that he mentioned so many interfaces, it could just as easily be that he wants to use other features of the interface, and I’ve already written quite a bit about that.
In any case, it’s becoming increasingly important to look for USB because FireWire is receiving less and less support from operating systems. Plus some other technical things where I already commented on.
I mentioned the Digiface USB because it costs new with warranty only €415, where a used UCX (which he mentioned) can already cost more (looking @ eBay Kleinanzeigen in Germany and @ ebay.de: around €575-€625).
See buying a new interface as solving a problem you have now with your old babyface. If you have no problem, there is no need. Even better is for solving a problem, like not enough gain on the mic pres. But if you dont need more gain....
Btw I really like my BF pro fs. But I work just as good with my hdsp9632 or adi8ae
yea, I'd stick with the babyface unless you want some other features like room eq or crossfeed for your headphones which the UCX II would have, alongside a bit higher gain on the preamp (I think +75 dB instead of 60).
