1 (edited by dreikelvin 2026-10-16 19:47:29)
Topic: [Solved] Loopback Recording Stereo Drift
I tried re-recording something off of my own material today and my hawk ears noticed a slight difference in the signal on the recorded file. First I noticed and already tackled the RoomEQ setting which was slightly changing the EQ - typical rookie mistake.
But there still seems to be something off. All the instruments are panned slightly more towards to the right. I can't explain it.
All of my input channels are centered. Master is centered. No weird stereo-width settings, all on default.
I am using a Fireface UCX II
Thanks for any hints
Re: [Solved] Loopback Recording Stereo Drift
More details about the setup, please.
Also please provide some test files, the original and the recorded signal. Preferably use test tones or the like.
Screenshots of Totalmix (including matrix view) would also help.
3 (edited by dreikelvin 2026-10-16 18:30:29)
I made a few test files for this occasion.
original with some clicks I recorded: https://drive.proton.me/urls/JKPXQXVT54#hkYcgmorPLF4
re-recorded: https://drive.proton.me/urls/R32T8FRSPC#gpoqMrquxKhd
screenshot of my totalmix window: https://drive.proton.me/urls/NEFAHS7B94#HZJQl6bZhYww
please use headphones!
Please include the matrix view.
file stereo comparison:
original -> https://drive.proton.me/urls/BJRY07X638#kPjKHuiOQ7kO
loopback -> https://drive.proton.me/urls/5565N3PN30#CT3Dklijo0MJ
matrix: https://drive.proton.me/urls/ZHF9DNV0BW#YMnLkw0VIZ9o
forgot my setup:
I am using the interface with a Mac Studio M1 Ultra on Goldengate
Hooked up to an Arturia Audiofuse for some ADAT inputs, nothing more complicated. I never messed with any input or output channels. Could this be something driver or OS related?
What is the driver and firmware version...?
What's the exact signal path? What are you "rerecording"? Just playback and recording through the internal loopback?
9 (edited by dreikelvin 2026-10-16 19:05:23)
Driver: v4.27
Firmware: v43
I was simply playing something back via the MacOS Finder (system output)
Maybe I can try playing back inside my DAW...will get back to you soon
ok, it gives the same result tongue
I just updated to Driver v4.30 and Firmware v43 but the situation hasn't changed
11 (edited by dreikelvin 2026-10-16 19:41:29)
I did some more tests.
This time, I wanted to see if my audio-in channels are affected, so I recorded an external device triggering a noise sound. The recording comes in completely fine. Result: https://drive.proton.me/urls/55CC10A674#dV2wCYvfszQt
Then I loopbacked it again and the signal started audibly shifting. I re-recorded over and over 6 times. Result here: https://drive.proton.me/urls/SQFH8JGBJ8#yQ4t8PG2ufav
What's strange is that all of my stereo analyzers do not show (much) difference. In fact, in the 6x exaggerated example, you would expect that the L channel is much quieter than the R channel. But both channels are at nearly the same RMS values.
I hope the internal loopback isn't broken hmm
12 (edited by dreikelvin 2026-10-16 20:59:24)
Recorded the Main Out using the onboard USB recorder - the resulting recording and the stereo signal is fine. This really just seems to occur when recording virtually via the Loopback function
13
You switched the Room EQ off? Are VolCal and Delay set to 0 as well? Or at least set identical for L/R?
That's it!!!
Now why would this setting not become inactive when I switch the RoomEQ off? Seems logical to me...
Anyways, I'm glad I could fix this issue now. Thanks so much!
