Topic: Class compliant mode control protocol specification
I own a MADIface XT II and use it in class compliant mode as the mixer for a hardware setup. My goal is to control the on-device mixer (routing, mixer gains, output volumes, eq, dynamics, etc) from another hardware device connected to its USB port, without a computer running TotalMix FX in the loop.
Without documentation I'm going to need to undertake a lengthy observation, packet capture, and capture analysis effort. I've started by reading the USB descriptors and taking a few initial captures with the RME driver and TotalMix FX running on Windows in a virtual machine. So far I've deduced that the mixer is controlled by register writes over one of the vendor-specific interfaces. If I continue this effort, I fear the end result will be buggy at best, or at worst, have some sort of negative affect on the hardware.
Would RME be willing to publish the register and USB control protocol specification for the MADIface XT II? That would make it practical to build a small, embedded client that controls the mixer in CC mode. The register SysEx protocol that other Class Compliant RME units carry on their MIDI port (as utilized by oscmix) would be an equally good answer, if the MADIface XT II supports anything like it.
Thank you for considering this.
