1 (edited by OroboroMusic 2026-10-25 09:44:47)
Topic: Fireface UCX: open-source Linux driver and mixer (normal USB mode)
Hi everybody!
I've used the Fireface UCX for years and always missed it on Linux, I switch between Windows/Linux laptop, so changing CC all the time is quite annoying, so I've been working a driver for it which is finally ready and working.
Its open source (GPL) and runs the UCX over USB in its normal mode, not class compliant:
- A kernel driver (ALSA): 18 in / 18 out up to 48 kHz, 14 / 12 channels at double and quad speed, all rates from 32 to 192 kHz, and both MIDI ports. Installs with DKMS and works with anything that uses ALSA or PipeWire.
- A mixer app laid out like TotalMix: the submix of every output, pan, mute, EQ, low cut, dynamics, auto-level, preamp gain and Hi-Z, phase and width, snapshots, and the unit's own level meters.
- A userspace driver as an alternative that needs no root.
Source and instructions:
https://github.com/OroboroModular/rme-f … nux-driver
Re: Fireface UCX: open-source Linux driver and mixer (normal USB mode)
Sounds fantastic, upcoming user reports will be interesting.
Cool! This looks very similar to the project I just built and posted here:
https://forum.rme-audio.de/viewtopic.php?id=43765
