Topic: Fader group behavior GUI vs encoder
I have set up a fader group for a surround setup on my UCX II consisting of main and analog 3 -5. The levels of the analog channels are a few dBs higher to align loudness between all speakers. I am using TotalMix 2.10 under Windows 11.
Lowering the volume of main to -inf in the TotalMix GUI also lowers the volume of the analog channels to -inf. When doing the same via the encoder on the device, main also goes to -inf but the analog channels stop at -45.5 dB.
I would like to have the same behavior with the encoder as the GUI. Is there some setting I am missing or could this be changed in a future update?
Re: Fader group behavior GUI vs encoder
Maybe just a side note. If you leave the faders all in the same position and adjust the level with the volume calibration from the RoomEQ? That's what is there for.
Audio AG Support
How to do this from the front panel ?
That, if all the faders are in the same position it works on both. But I agree, the behaviour is inconsistent if the faders are different.
Audio AG Support
5 (edited by waedi 2026-10-29 10:46:41)
How to select the room EQ Vol.cal. for the encoder ?
User manual page 13 menu structure does not include it.
You set that in the Room EQ of the "main" channel.
Try the following. Disable the group. Set all faders to 0 db (speakers switched off for security). Then enable the group. Set the volume calibration in the RoomEQ for each output channel. Then it works both ways.
Audio AG Support
What do you mean with "set" ?
How will the encoder of the unit get control of the vol.cal. in room eq ?
Sorry for asking, just curious.
It doesn't. The encoder just controls the main fader in TotalMix FX. And that one is calibrated. Just try it, it will work. I just tested this.
Audio AG Support
Did try, the main fader has no influence to the vol cal
10
Yes, we have plans to fix this behaviour in later updates of TM FX.
Indeed that's what you want, that it stays one and same value while changing the faders in a group. it doesn't matter if you  control in TotalMix or with the encoder.
https://imgur.com/gallery/tmfx-group-ca … on-NjfAFpK
Audio AG Support
12 (edited by ety 2026-10-30 00:51:31)
Great, thank you very much. RME at its best as always :-)
Also thanks @Audio AG Support for the tip with volume calibration via Room EQ. Works nicely, although +3 dB was not enough, so I had to reduce the volume level of main additionally.
