Topic: DIGICheck for Mac - require "Check Status Display" function
Because the hardware I'm using to receive the digital output of a FF400 does not show bit depth and sample rate, I would like to be able to monitor this at the FF400 playback (i.e. the Firewire output) and FF400 output. I guess that this would be possible with the Channel Status Display function available for PC but not (yet?) available for Mac.
If this is not likely to be available, can anyone recommend software to display the bit depth and sample rate being output on the Firewire channel?
Thanks in advance
David
