Topic: 9632 under linux
Is anyone had success with the hammerfall 9632 under linux Ubuntu ?
I've find out that only digital output were working !
Re: 9632 under linux
look at www.alsa-project.org
and specially at http://www.alsa-project.org/main/index. … Vendor-RME
It's all done. I already tried to reinstall the driver manually. Also, when you install the card in the computer, it is automaticly detected.
But no sounds. Can you help more with the issue.
you must unmute the channels because they are muted by default. For that use amixer, alsamixer command to see all of the channels, to set the level and the mute/unmute state.
Tell me back if it works with that command.
