Topic: DIGI9652 Hammerfall breakout cable
I'd like to use coaxial SPDIF on my DIGI 9652. I coudn't find the breakout cable so I ordered
RME Digital SPIDF Breakout Cable (BO9632) . That doesn't work (connected to a TASCAM DAT Player, In or Out).
from what I gather, that cable maybe has this configuration:
Pin Name           Pin Name            Pin Name
1 GND              4 AES Out +         7 SPDIF In -
2 SPDIF Out +      5 AES In +          8 AES Out -
3 SPDIF In +       6 SPDIF Out -       9 AES In -
but the 9652 manual states:
Pin assignment of the cable adapter:
Pin Signal          Pin Signal
9 SPDIF In +      5 SPDIF In -
6 SPDIF Out +   1 SPDIF Out -
Which cable do I really need (is there a part number 36018 I can order from somewhere)? Anybody want to sell me one?
thanks,
John
Re: DIGI9652 Hammerfall breakout cable
Problem resolved. I need the RME Breakout Cable BOHDSP9652, not BO9632. Thanks to tech support.
I did spend some quality time sodering a cable (cutting up some DB-9 cable laying around the house) that works with the pinout as the 9652 manual states...
3 (edited by tonyrob 2011-08-27 03:01:40)
I have used 9636(52) for more than 15 years with Spdif outpu,input. I plan to use XLR, and diy a XLR cable. What is the Pin assignment for AES out on DIGI9636/52.
thanks a lot for reply
Manual chapter 21.2.
Hi, Matthias,
thank you for the fast reply.
In the manual,
21.2 Pin assignment of the cable adapter
I only see SPDIF out, no AES out, no Ground.
Shell I use SPDIF +/- as AES+/-, without Ground?
My even older 96/8 pad works in a differant way. D-sub has both SPDIF out and AES out.
Pin assignment of the XLR/RCA Cable's D-type connector
Pin Name
1 GND
4 AES Out +
7 SPDIF In -
2 SPDIF Out +
5 AES In +
8 AES Out -
3 SPDIF In +
6 SPDIF Out -
9 AES In -
6 (edited by tonyrob 2011-08-30 02:14:36)
Does anybody know how to get the AES out from the DIGI9636(52)'s 9 pin D-type connector?
Thanks,
7
By checking 'Pro' in the Settings dialog (and further reading of the manual...).
