Topic: TotalMix FX not controlling Octamic D
Hi, I'm using the UCX interface linked to an Octamic D through ADAT. In TotalMix FX screen I can see that all functions (faders, gain, FX, etc) work correctly for the UCX inputs but not for the Octamic (although I can see that the signal is passing through perfectly from all units and I can hear all Ins/Outs). It looks like I can only control the inputs of the Octamic D through its hardware front end volume/gain knobs. Could you please assist?
Re: TotalMix FX not controlling Octamic D
Why you think that you should be able to control the mechanical potentiometers from the OctaMic D  by software? Where does it say so? In the manual it clearly says OctaMic XTC.
Ok Matthias, many thanks for the prompt reply, you're referring to the UCX manual right? I just wanted to make sure I haven't missed anything. Thanks!
Correct.
