1
Topic: TotalMix FX 1.08 available
Version 1.08 is a quick hotfix for Fireface 400, Multiface, RayDAT and HDSP 9632, and adds some help for ADM users. The details:
Windows:
- Fix for Fireface 400: Gain changes in input channel 3 did set hardware output 1/2 to -1.0 dB. This fix also requires the new driver 3.114 (TM FX 1.08 is installed with that driver).
- OEM only: bug fix ADM with playback channels (some companies use ADM also with playback channels to control levels via TotalMix. This bug had no impact on DAW software like Cubendo and such).
Windows and Mac:
- Fixed wrong channel usage of the Aux feature (OctaMic XTC remote) with Multiface, RayDAT and HDSP 9632.
- New options under Options, Reset Mix: Set all channels mono, set all channel stereo, set all inputs mono/all outputs stereo (ADM). These new options help to set up bigger MADI cards to all channels mono. They also help when using the new TM FX extensively with ASIO Direct Monitoring, as you can now easily set TotalMix to the most compatible mode (all inputs mono, all outputs stereo).
Please note:
- although these options do not cause a complete reset of the mixer, the pan settings still get lost.
- If you accidentally used one of these options, don't worry: Undo will bring back the former mixer state
- Using these options with high channel count cards (MADI XT, MADI FX) will take a few seconds until the changes are applied. Therefore to get back to the former state multiple Undo are required.
Mac:
- Workspace and Snapshot files could not be used with other devices than the original one (HDSPe serial number mismatch)
Download: We have uploaded new drivers to our website for all current products with included TM FX 1.08.
