Topic: Anyone used the MADIface Pro with third party MADI units?
We're recording a show this weekend where the FOH system uses a Soundcraft Vi3000 desk.
It has an SC output.  Will this work seamlessly MADIface Pro?  Will Totalmix read all the output channels or just those being used?
Also, is it possible to combine with one or two Micstasies in the MADI chain?
Thanks in advance
Eastwood Records
www.eastwoodrecords.co.uk
Re: Anyone used the MADIface Pro with third party MADI units?
For those who chance upon this thread, the Vi3000 integrated beautifully - we used the analogue ins on the MADIface to record the audience!
Eastwood Records
3 (edited by ramses 2018-03-17 18:20:27)
With MADI you can build a ring
Device A Out -> Device B IN, Device B OUT -> Device C IN, Device C OUT -> Device A IN
EDIT1: each multimode fiber cable between 2 devices may be up to 2km long. Take i.e. this OM4 multimode cable: https://www.reichelt.de/LWL-Kabel/O0318 … SEARCH=OM4
On the device it should be configurable which Inputs you want to map to 1..64 MADI outputs (assumed you use the format with 64 channels.
Here you can see my setup with UFX+ and 2 Octamic XTC connected via MADI ...
https://www.tonstudio-forum.de/blog/ind … Cber-MADI/
Written in German, but the config stuff should be readable / understandable ...
