Topic: Recommended method for changing sample rate
Our MADI rig often behaves unpredictably when attempting to change sample rate.
We usually run 2 x Micstasy + 1 x XTC into a MADIface Pro with the first Micstasy set as master and everything else slaving via MADI.
When I tried to change the sample rate from 44.1k to 96k, the MADIface kept getting stuck on 60k. I tried using MIDI Remote software, switching on the devices themselves and through Reaper which has an option to control sample rate. I even tried setting the MADIface as master, but none of these methods worked.
What is the recommended procedure for changing SR? Should I expect the slave devices to be changed manually as well as the master (either remotely or in person)?
www.eastwoodrecords.co.uk
