Topic: TotalMixFX crashed and burned
It's been some time since I tried my hdsp card and when I opened up totalmix it was not looking too healthy, then it vanished from my startup dock. So I installed the latest version and it won't open. How to I get it back?
Re: TotalMixFX crashed and burned
Does your HDSP card work at all? Even without TM FX you should be able to start playback and record.
Hi Matthias, when I opened up Sonar, the hdsp was gone from list of devices - a first. The updated version of TotalMix is in my dock but won't open the mix screen.
Of course it doesn't - it needs the card to work, and that card is no longer in the system. Remove it, clean the gold contacts with a rubber eraser, re-insert. If still not work check the Device Manager.
That worked, thank you Mathhias.
