Re: Recommended reading for EQ
A few updates:
1 yes the Antimode mic needs a special preamp and I am using that
2 Windows did indeed use the internal mic so I changed that to make it use the extrnal mic. Checqued this
3 REW was also set to use the internal mic so I had to change that
4 I did not yet calibrate the mic but that changes relatively little
5 I did some new measurements and they still show a significant drop below 100 Hz when using just the main speakers. Adding the sub fills in the realy low bass but the dropping output between say 50 and 100 Hz is what really bugs me.
So is this still kind of measurement error, given that my Sennheiser and its external soundcard gave such a nice flat response (apart from the localized peaks and dips)?
I ordered a Umik but having paid for it I received an automatic message from mini dsp in the Netherlands that due to the holiday season this will only be delivered after mid August.
One last option that I will investigate is to check the laptop sound card and see if it has some high pass setting activated. Otherwise I think I will just have to wait until the Umik arrives
