Topic: no sound in my headphones
i have no software outputs in my total mix window and i cant get sound out of my headphones, help please
using fireface uc on windows
Re: no sound in my headphones
Hi, your post is unclear, can you add some detail?
Means the whole row is missing? Or you just do not see any meter activity?
the row doesnt exist
in general theres no sound coming out of my headphones (plugged into the front of the fireface uc in MONITOR CH 7/8) meanwhile my monitors are working just fine, and im fairly certain the issue is with the total mix (headphones work when i plug them into other devices) ive been trying to look it up online and everyone is on mac and has a middle row with software inputs (im on windows and i dont have that row)
also i see videos saying to select my headphones channel in total mix, i dont seem to be able to select any of the channels there (not sure if channel is really the right word here)
just noticed it says ufl where my headphones channel is, how to fix?
You might have changed the channel layout of TM FX to hide all channels in this row ?
I suggest to reset TM FX entirely: Options -> Reset Mix -> Total Reset
and then, to have a good starting point: Options -> Reset Mix -> Straight Playback with All to Main Out
Then follow the step by step primer: https://www.tonstudio-forum.de/blog/ind … rnal-equi/
The RME video tutorials are also very helpful to get a good and fast introduction about TM FX:
https://www.tonstudio-forum.de/blog/ind … al-Videos/
i did total reset and tried the straight mix option with no luck, i will try this link now thanks
Its strange, that you see no SW playback channels, could you pls post a screenshot ? Thanks.
That is daw mode vs submix mode. Make sure you are in submix mode!
Ah good idea, its btw "daw mode" vs "full mode", not "submix mode" wink
