Topic: Control multiple outputs with UC's rotary encoder?
I have a pair of custom 3-way speakers, powered by a 6-channel amp. Currently I use an external (rackmount) electronic crossover to filter the stereo output (from an HDSP card) into the 3 frequency bands.
I'm thinking of changing this and doing the crossover filtering in software. This will mean that instead of using just 2 outputs from the card, I will now need 6.
In fact, for other reasons, I'm thinking of changing from the HDSP to a Fireface UC interface.
My question is, is there any way that I can use the rotary encoder on the UC to control 6 output channels (in Total Mix)? I need this in order to have a single monitor volume control. I can't work out from the UC manual and playing around with Total Mix whether or not this is possible.
Hope that makes sense.
Thanks, Ian.
