RobHu wrote:Thank you jiw.
Ramses: Sorry, I may not be using the right term - at present with the LCD-3 I'm using one of these https://www.dysonaudio.com/products/dys … le-adapter
Mark from Audeze said "you might need a balanced cable with them instead of single ended?" I think that is what I'm currently using?
Mytek seems to not follow the same convention for symmetrical connection as RME. From the manual of the Manhattan DAC II:
Headphone Output Section, Dual Mono, with Balanced Operation mode. Top jack connects unbalanced
phones in absolute phase. Bottom jack connects unbalanced phones in absolute out of phase. A
special 2x 1/4” jack to 4 pin FXLR allows for connection of single balanced headphones.
Thus for that adapter, tip on red is L+, ring on red is R+, tip on black is L-, ring on black is R- and sleeve on both red and black is ground.
For the RME in symmetrical phones connection (manual p. 41), tip on Phones 3/4 is L+, ring on Phones 3/4 is L-, tip on Phones 1/2 is R+, ring on Phones 1/2 is R- and sleeve on both Phones 1/2 and 3/4 is unconnected.
Thus, using the mentioned cable while using the RME in symmetrical Phones connection gives L+/- to the positive and R+/- to the negative input of the connector. So you would have mono on both sides but one side inverted.
However, you might also have this cable intended to be used with the RME: https://www.dysonaudio.com/collections/ … le-adapter
Try using symmetrical connection and enabling M/S-processing. If nothing changes, you have got the wrong cable.
