Topic: ADI2 and Radyat ADAT Sync
I am using the ADI-2 Pro FS in connection with a HSDPE Raydat.
The Raydat is set as the MasterClock.
The setup Is as followed:
ADAT 1 : Some other external ADAT device (not RME)
ADAT 2: ADI-2 Pro FS
ADAT 3: not used
ADAT 4: not used
AES: Some other Device (not RME)
ADI-2 Pro FS is set to auto concerning clock.
When I do change the samplerate, I can see also the change on ADI-2 side.
Sound comes out, so it seems to be OK.
However: I do not understand why the ADI-2 is not seen to be synchronized on the settings dialog of the Hammerfall DSP .
The first device on ADAT 1 is shown, the device on AES also.
But on ADAT 2 , where the ADI-2 is connected, nothing is shown that a sync or lock will be done.
In detail the appropriate group box looks like that
---Input Status---
ADAT 1 Sync 48 khz
ADAT 2 No lock (=> here, the ADI2 should be shown somehow, or?)
ADAT 3 No lock
ADAT 4 No lock
AES Lock 96 khz
SPDIF No lock
TCO No lock
Sync in No lock
Clock source for Raydat is set to Internal / Master
I am confused, why isnt it shown?
What do I understand wrong?
Thanks in advance for your answer and help.
