deliad wrote:[...]
I know we have the same motherboard ,Thats why i'm so in-pressure about it , i don't want to loose money and buy ufx and to still have problem to using it and get it to work under my x570 ASROCK Creator Motherboard and my 3950x cpu.
Can you confirm that on 64@44100 the UFX is stable?
Please try to understand why im pushing to more clarified answer, Buying UFX is not cheap to deal with problems later
Hi deliad. Is it an UFX+ like you tell in the subject of this thread or is it the older flagship model UFX like you write in the text?
Please note these are different recording interfaces with even different USB ASIO drivers.
May I suggest that you contact PC builders that specialized on building turnkey systems for audio?
It can be the case that a certain mainboard or hardware combination is simply not ideal for audio and
RME can't do nothing to solve this.
If you do not get it resolved by yourself and if you have special low latency requirements that it has to run with even a low amount of 64 samples ASIO buffers, then I would strongly suggest to contact such companies to get consultancy, whether your requirements are realistic and to get a turnkey system for this purpose.
It also depends on the system load, you can't simply state "I want to work with a setting of 64 samples ASIO buffers" if the surrounding conditions (load of the PC, selection of components) maybe do not allow for this.
And if you ask here in the forum its difficult to support it, because only few people will have exactly the same hardware composition as you have in your machine. Same applies to versions and settings of BIOS and drivers and especially in terms of system load (CPU, i/o).
I am really sorry, but the general PC tuning tips you might know already, you might also have got the sonnet card and you might also know that you can either use Win10 drivers for the Sonnet card or maybe more up to date drivers directly from fractal logic. You might maybe also know, that Win10 has limitations compared to Win7, that its not possible to priotize more than 32 threads with MMCSS (-> whats your core/thread count of your CPU ?). If this is not manageable anymore by yourself or a "remote support" of a forum, you should get the tested hardware of such a PC specialist for audio.
A well known company with very good reputation is Xi Machines:
http://xi-machines.com/de/systeme-audio.php
They offer a broad mix of HW up to Xeon builds.
