Topic: UFX+ 15m cable possible?
Hi!
I just bought a brand new UFX+ device and tried to use it with a Lindy 10m USB cable:
https://www.amazon.de/gp/product/B07B95 … &psc=1
The host LED lights up on the device, but Windows 10 does not recognize the UFX+.  If I use the USB cable that comes shipped with the device, everything works.
Can someone recommend a 15m USB cable that works with the UFX+ ? Or is this not possible at all?
Thanks for your help,
Matt
Re: UFX+ 15m cable possible?
First that link is for a 10 meter cable (?), second such cables don't work. With USB 2 yes, with USB 3 no chance.
At 15 meters I know of only one solution, the optical USB 3 cable from Corning. Expensive, but works.
https://www.amazon.de/Corning-USB-3-0-K … 00M2FYSYA/
5m works reliably with a Lindy Premium cable.
LINDY 36664 5m USB 3.0 Typ A an B Kabel, Cromo Line Anthrazit
https://www.amazon.de/dp/B07F6WHVLH?ref … E_DDE_dt_1
Maybe you can organize the location of devices differently, i.e. bringing PC and UFX+ closer to your desk ?
ADAT TOSLINK cables work usually fine up to 15m up to 192 kHz, maybe even 20m.
MADI can be up to 2km between each of the devices, OM3/4 patch cables are available up to ~30m.
BR
Ramses
Thanks for your answers! I will give the optical cable a try.
5 (edited by hselters 2020-02-21 18:21:30)
If you are not using MADI then I would recommend setting the UFX+ to USB 2.0 mode, this is working fine here with a chain of several cables and a USB switcher in between. Total cable length is about 7m, the last cable is a cheap 5m USB 2.0 extension with a passive repeater. Maybe even longer runs are possible using active USB 2.0 Hubs.
I am also using an optical thunderbolt cable from Corning. The plug sits a little loose in the thunderbolt port and is very sensitive against any mechanic movement. It works fine for me in the studio, but I would not use it on stage.
With the good old FireWire it was much easier running 15m long cables.
After some ups and downs, I am back to report about my experience. Maybe it helps someone else...
I went for the expensive, optical USB cable but still had problems (mostly errors in the settings) in the USB 3 mode. After I manually but the UFX+ in USB 2 mode, everything works fine now. I know i can't use the full potential of the interface, but currently it's enough channels for me.
Thanks to all the help.
7 (edited by hselters 2020-03-09 16:18:39)
Oh, with USB 2 the optical cable is probably over the top, as it might be doable with a cheap standard repeater cable, see my comment above. A shame it does not work with USB 3.
For using all channels of the UFX+ the only other option to try would be trying thunderbolt then with the optical cable.
I tried the USB 2 mode with a cheaper cable - I had lot's errors showing up in the settings dialog. This solution works for now and some day in the future, I will bring my UFX+ closer to my computer and put a multicore into my studio....
I'm actually using my Fireface UCX with a 32 foot USB cable. It works perfectly in every aspect: recording and playback. Here's how it's connected:
Fireface > default USB cable that came with it > USB 3.0 powered hub w/ 6ft cable > 32 foot USB 3 cable > computer
This is the link to the 32 foot USB 3.0 cable.
https://www.amazon.com/gp/product/B076C6PDNH
