Topic: Additional/Replacement Power Supply
I'm a relatively new owner of an RME ADI-2 FS Dac and loving it so far.
Main purpose of the purchase was for using as and Dac and headphone amp for my PC, but since it sounds so great I also want to use it in with my stereo speaker setup in another room.
Initially I was considering just buying another ADI-2, but a more cost effective solution for the time being would be if I had another power supply which I could have set up in the other room. This way all I'd have to do is move the dac and disconnect/connect the inputs. Moving one power supply every time I do this presents issues with accessing power bricks and cable management.
Is it possible to purchase just the ADI-2 power supply from somewhere, or is there a suitable alternative?
Re: Additional/Replacement Power Supply
Its possible to get a 2nd power supply.
Thanks, I did see on the RME product page that there is the power supply for the ADI-2. I've just not seen anywhere I can actually buy one unfortunately.
4 (edited by ramses 2020-03-28 08:54:06)
This article is missing on the RME website, I found it at Thomann under "RME power supplies":
https://www.thomann.de/de/rme_ntcardbus_x.htm
Not sure whether this is an official RME product, maybe a reference is missing in the manual,
that the name of the RME product is: RME NTCARDBUS-X
And then it should be added to the webserver under Products -> Accessories.
You could also use other power supplys according to the specs in the manual:
External switched power supply, lockable connector, DC 12 V 24 W
Power supply 12V DC, 1.0 A or up
Included power supply: external switching PSU, 100 - 240 V AC, 2 A, 24 Watts
Powercords for EU and UK:
https://www.thomann.de/de/the_sssnake_kgskabel.htm
https://www.thomann.de/de/thomann_power … 3a_14m.htm
5
No, it's not. Took me 5 seconds to find it. And it's in the manual as well.
Would something like this be ok? https://www.amazon.co.jp/dp/B07TVG1M1B/.
Sorry I'm based in Japan so this is in Japanese, but seems like this meets the power requirements.
Strange Matthias because I could not find it and my last update of manuals is not too long ago (Sept 2019).
ADI-2dacr_e.pdf
Copyright © Matthias Carstens, 12/2019. Version 2.2
Searach for "ntcardbus" (ignoring case) -> no match
Search on website for NTCARDBUS or NTCARDSBUS-X
Search results
Keine Ergebnisse für ntcardbus (0.0054 Sekunden)
Also when looking into the latest manual I am getting no hit on the subscring ntcard or NTCARD
https://www.rme-audio.de/downloads/adi2dac_e.pdf
