Topic: RME Fireface UFX ii problem with Microsoft Surfacebook 2
Background - I have been using RME products since the multiface and card bus days. After this I upgraded to a Fireface 400 and about 2 years ago started using primarily a Babyface Pro with the Fireface 400 as an AD converter into the Babyface.
The Babyface Pro has been rock solid on this Surfacebook 2.
Recently I purchased the UFX ii to enable more IO and reduce clutter on my desk by mounting in a rack.
After installing the new interface everything appeared great. Playback through the unit performs well, live routing all fine. Only when I started to monitor inputs over ASIO when recording into Ableton did I notice the issue.
It appears that as soon as I hit a key on the computer keyboard it causes this distortion. Kind of like being played through a ring modulator. After a moment or two the sound returns back to normal until I hit a computer keyboard key again.I have tried with Cubase 10.5 and the same issue is present.
This is a fresh install of Windows 10 with only the RME driver and Ableton Live Suite 10.1.3 installed. No other peripherals are attached to the laptop, the power mode is on best performance. Wifi disbled or enabled does not make a difference. I have tried all USB ports (2) and have tried a USB-C hub with USB 2 ports and the same problem exists.
Tried changing USB cables
Driver: 0.9716
Hardware Revision: 20
I have made a short video that highlights the issue. Please excuse the background noise in the video.
https://youtu.be/O_nQ0ODtDS4
Can anyone offer a clue, is the unit defective?
Lynden
OS Name Microsoft Windows 10 Pro
Version 10.0.18362 Build 18362
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name PLUTO
System Manufacturer Microsoft Corporation
System Model Surface Book 2
System Type x64-based PC
System SKU Surface_Book_1793
Processor Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz, 2112 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Microsoft Corporation 389.2837.768, 21/08/2019
SMBIOS Version 3.1
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Microsoft Corporation
BaseBoard Product Surface Book 2
BaseBoard Version Not Available
Platform Role Slate
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United Kingdom
Hardware Abstraction Layer Version = "10.0.18362.752"
Username PLUTO\lynde
Time Zone AUS Eastern Standard Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 9.64 GB
Total Virtual Memory 18.8 GB
Available Virtual Memory 10.9 GB
Page File Space 2.88 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
