1 (edited by Logix 2020-05-17 05:28:29)
Topic: Digicheck and Logic Pro meters showing different values.
I can't get Digicheck level meter (or Totalmix FX meters) to show higher value than 0.1dB when working with Logic Pro X.
I'm using Test Oscillator and Logic's gain plugin for that.
Test Oscillator plugin on 0dB and gain plugin on +24dB.
When i'm on 20Hz tone I see 0dB on Digicheck level meter and +24dB on logic's meter.
When i'm on 20,000Hz tone I see 7.4dB on Digicheck level meter and +24dB on logic's meter.
Is it a bug or am I doing something wrong? I would like to see the exact same numbers on Digicheck and Logic if possible.
This is with the new Digicheck NG - Intersample peak is checked, i've tested both OSX 10.13.6 and 10.14.6 with the same result.
Here is a screenshot:
https://i.ibb.co/pPPjb6C/Screen-Shot-2020-05-16-at-7-55-34-PM.png
Re: Digicheck and Logic Pro meters showing different values.
One is seeing the internal bus level for output, one the hardware level at the input...there can be no '+24 dB', only 0 dB plus overload.
I see.. okay I will have to get used to it, I always used plugins for metering but the new Digicheck is so good that I won't use anything else from now on.
Thanks for the help.
