Topic: Setup Change via Remote or automated
Hi all,
I need Multichannel Operation with the RME ADI-2 Pro via USB connection and 2 Channel via Optical in. I understand that I can safe that in 2x Set-ups, but can I change the Set-up via Remote or can I make the RME change the Set-up automated based on the Input Signal?
Context: I need Subs in the USB Operation, but not with Optical Input and don‘t want to shut subs off, when not needed, nor change the Set-up manually.
Can‘t get a clue on this via the Manual.
Thanks for info / advice!
Best Jin
