1 (edited by hpw 2019-06-25 15:02:20)
Topic: Subscription/notify for Firmware/Driver Updates ADI-2 Pro & ADI-2 DAC
This thread is a "Firmware/Driver Updates ADI-2 Pro & ADI-2 DAC" subscription notify ONLY thread!!
This means, all are welcome to "Subscribe" to this thread and get a notify as soon someone sees a beta or release Firmware or Driver published from RME and add's a related message.
How to subscribe: Login and than you will see a "Subscribe" Menu entry on to top left blue bar and simple click to this to get the update news letter. big_smile
Hp
Re: Subscription/notify for Firmware/Driver Updates ADI-2 Pro & ADI-2 DAC
Firmware Updates ADI-2 Pro 193 / 94 and DAC 26 / 29 out now: https://www.forum.rme-audio.de/viewtopic.php?id=28936
New windows driver:
Windows 7 to 10 PnP driver for MADIface XT/USB/Pro, Fireface UFX+ / UFX II, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, Digiface USB. Version 0.9685
https://www.rme-audio.de/download/drive … _09685.zip
[ADI-2 DAC] New firmware
Firmware Update ADI-2 DAC 26 / 30 - Remote it!
[ADI-2 Pro & DAC] New firmware
Firmware Update ADI-2 DAC 27/32, Pro 213/96 - Fix it!
Firmware Update ADI-2 DAC 27/33, Pro 213/97
https://forum.rme-audio.de/viewtopic.php?id=29439
7 (edited by hpw 2020-03-15 14:04:05)
Firmware update on DSP part..
ADI-2 Pro series: FPGA 213, DSP 98
ADI-2 DAC: FPGA 27, DSP 34
8
No update:
https://forum.rme-audio.de/viewtopic.ph … 72#p148272
Flash Update Tool for MADIface XT/USB/Pro, OctaMic XTC, ADI-2 Pro Series & DAC, Digiface USB, UFX II.
2020-09-17
Update to firmware revision MADIface XT: 191/56/42, USB: 25, Pro: 73. OctaMic XTC: 47/26. ADI-2 Pro: 238/98, ADI-2 DAC: 34/34, Digiface USB: 14, UFX II 20/11/7.
Supported products
ADI-2 DAC FS, ADI-2 Pro AE, ADI-2 Pro FS, ADI-2 Pro FS R Black Edition, Digiface USB, Fireface UFX II, MADIface Pro, MADIface USB, MADIface XT, OctaMic XTC
2020-09-17
Supported products
BTW .. appears to me the same as post #7, could you kindly review ? I will remove my post here after a while to clean-up.
11 (edited by bejoro 2020-09-26 12:44:42)
The version nunbers should be clear.
Post #7 is a different and much older  firmware. The new firmware is from 2020-09-17.
12 (edited by ramses 2020-09-26 13:04:38)
Never too late to learn a new trick.
Thanks, up to now I thought that only the DSP version (which is shown on power-on in the display) would be relevant to identify, whether a firmware upgrade is needed.
I think then it would be better to display both numbers on power-on, the USB and DSP version to make it clearer, whether an upgrade for a particular device is required.
Especially as this updater is for different devices and sometimes there is only an update included for some of them.
@RME: would that be possible ?
Thinking back to the good old Webserver, where this update information was based on the device not on the driver (where you have to look closely, whether it contains an interesting update). That was much easier and clearer.
Yes that would be very helpful. RME please show FPGA and DSP version of the firmware at startup.
2020-09-17
Supported products
I can't find version history / change log, what's new?
Because there is none yet.
Thanks,and where can I found what changes are?
17 (edited by bejoro 2020-09-26 14:43:17)
Download the flash updater tool for your OS and look into the readme.txt.
Not very detailed but a hint.
09/17/2020 ADI-2 Pro updated to 238/98, ADI-2 DAC updated to 34/34. Current peak on power-on reduced.
Maybe MC will provide a more detailed change log if he finds the time (and if necessary).
Are all firmware and driver updates supposed to be announced here? The reason I ask is I just noticed driver update 0.9728 when I checked at the support page directly (dated 2020-10-31) that does not seem to be mentioned here. It seems official (not mentioned as beta) so I'm wandering why it would not be announced via this sticky thread?
You just did. Thank you.
This is a thread for notifications only. Please open a new thread if you have questions.
Ok - I assumed this was supposed to be announced by RME folks but if its open to anyone to mention it when they notice new versions that works as well.
22 (edited by N00b 2021-03-17 18:11:19)
Firmware update: 249/98 for the Pro and 35/34 for the DAC
Link for Mac version
Link for PC version
More info...
23
Firmware update: 250/101 for the Pro and 35/35 for the DAC
https://forum.rme-audio.de/viewtopic.php?id=32772
Firmware Update ADI-2 DAC 66 / 47 and ADI-2 Pro 259 / 111
https://forum.rme-audio.de/viewtopic.php?id=34364
Firmware Update ADI-2 DAC 78 / 49 and ADI-2 Pro 262 / 113
https://forum.rme-audio.de/viewtopic.php?pid=185970
Firmware Update ADI-2 DAC 78 / 50 and ADI-2 Pro 262 / 115
https://forum.rme-audio.de/viewtopic.php?id=35356
Firmware Update ADI-2 DAC 78 / 48 and ADI-2 Pro 262 / 112
https://forum.rme-audio.de/viewtopic.php?id=34588
That is an older firmware.
Latest:
That is absolutely correct!
If you had not forgotten this firmware above, there would not be my hint!
Somehow strange posts, I think, yet anyway, there is a more recent firmware available - for both the DAC and the PRO. Have a look.
Cheers, Ernst
ADI-2 PRO FS R BE / ADI-2 DAC FS / some old multibit treasuers ;-)
31 (edited by RME_fan 2022-07-13 22:05:40)
bejoro wrote:
Latest:
There are news in the latest readme file:
"ADI-2 DAC 78/51, ADI-2 Pro 263/116. Pro/DAC Fix: Corrected display of B/T setting >9.5 dB in Dark Volume Screen. Bugfix Pro: 1 sample channel offset when SRC is active with an ADAT input signal."
There was indeed no subscription/notify message for this older firmware.
ADI-2 Remote Pre-Release: Step 1, macOS
https://forum.rme-audio.de/viewtopic.php?id=37669
