KillerQ wrote:KaiS wrote:KillerQ wrote:Brilliant!! I was actually contemplating that as well. Something just like this should work perfectly, right? TISINO Dual XLR Female to 3.5mm TRS Stereo Y-Adapter Cable Unbalanced 2X XLR to 1/8 Inch Mini Jack Y-Splitter Breakout Lead Microphone Cable - 5 FT https://www.amazon.com/dp/B07DMW8WXR/re … LFbG5DND8S
This one works.
I'd advice to cut the connection to XLR pin 3, as ADI-2 is not servo balanced and doesn't like its outputs to be shorted to ground.
Very easy to open the Neutrik style XLRs, they are just screwed together.
Nothing breaks if you don't, but the signal quality is better if you do.
Ok, since it’s just using using the signal to trigger LED lights, I’ll try it unmodified at first. I just found these though, they are even shorter which is great - and if you scroll through the pictures, they even show that you can unscrew them. Think these will suffice? NANYI XLR to 3.5mm Splitter Cables, 1/8Inch TRS Stereo Male to Two XLR Female Interconnect Audio Microphone Cable, Y Splitter Adapter Cable0.5M (1.6Feet) https://www.amazon.com/dp/B07H2T37ST/re … LFbKSWD3MG
Yes, works, same like the other one.
Still suggest to cut the Pin 3 connection, takes a minute, the pins are marked with numbers on the plug.
Else one half of the balanced output amp is fully loaded with it's 100 Ohms internal resistor all the time, too low to be driven with higher levels, so the amp distorts then.
Even though the amp won't break, I don't like the idea, and I'm not sure the internals are that much independent that there is no signal degradation on the RCA at all.
Read manual page 53, the "!"-part.
