Topic: ADI-2 DAC Line Outs stopped working
I've had the ADI-2 DAC for a while and it has always worked flawlessly, including last night. Today for some reason the line outs no longer function - both the XLR and the RCA outputs no longer produce any sound coming out of the amp (I've tested it with two different amps - a Massdrop THX 789 on the XLR outs and a Koss ESP 95/X Energizer on the RCA outs).
The spectrum analyzer shows that the ADI-2 DAC is receiving a signal, and the headphone output on the ADI-2 functions normally, it's just the line-outs that no longer work.
Is it possible there's a setting I may have changed that could cause this behavior, or has my unit suffered an internal failure that will require it to be sent in for repair?
Thank you.
