Topic: Speaker B with Babyface Pro FS
Posted in TotalMix but no response. I could do with support looking at this. Thanks
Topic: Speaker B and Babyface Pro FS
I setup speaker B in TotalMix which automatically links the slider with the main out. Great so when on main out I can use the dial on the BF and control volume and both main and B sliders go up and down. If however I switch to B the dial on the BF no longer controls the sliders. This seems wrong to me. If these are linked then even if I switch to B the dial on the BF should work. I don’t see the point in linking them if I can’t control with the dial once I’ve switched to B? Is this deliberate? My problem is if I’m using the dial and switch to B I have suddenly lost control from the BF and I have to jump for a software slider like I did today when they were too loud. Surely this is a mistake?
Next question. Is there no way to control the switch from main to B via the BF? I sort of hoped the mix B could do it but it doesn’t. It would be good if the buttons could have dual function when working with a computer as I don’t need most of what they do as I control from TotalMix or my DAW. Being able to control main and b from the same place as well as switch on the BF would be really useful although I’d settle for the linked volume to work as I’d expect. Thanks
