Topic: ADI-2 DAC and a power-amp for the millionth time..
So I've read other topics about this but still kinda confused so I thought I'd just make sure I'm doing this right;
I recently bought a new pair of passive speakers and a power-amp for them. I use the RME as a DAC for the setup. So I can just leave the ADI-2 on auto ref and control the volume from my separate amp and I'm all good? Or do I need to set it up in some other way? I tried reading about the specific volume-levels to make it act as just a DAC but whenever I try to set the ref level and the volume according to the other posts, I see clipping happening on the RME. So if I just leave it on auto ref, I'm all good? Thanks.
Re: ADI-2 DAC and a power-amp for the millionth time..
Auto reference level is fine.
Read this, CASE 2, to correctly set it up:
https://forum.rme-audio.de/viewtopic.ph … 21#p161721
Thank you very much!
Hi Exact!
If you use the volume control of the integrated  amp (a power amp does not have a volume controller), I would suggest to turn off the Auto Vol Ref on the RME and to use a fix and locked volume on the RME (I would calculat the ideal level volume of the RME depending on the sensitivity of your amp). To convert it: http://www.sengpielaudio.com/calculator-db-volt.htm
And don't worry about the overs: it happens because of the intersample peaks. Just don't go over 0 dB volume setting on the RME and you'll be fine. smile
The topic starter asked about using ADI-2 with a power amp, not an integrated.
If he mixed this up CASE 1 of the mentioned link is the way to go.
I don’t think a layman has a chance to understand what is going on with the dB calculator.
Intersample peaks only occur in the analog domain, and don’t hurt if the analog circuit’s part has enough headroom.
To display them ADI-2’s meter would need to work with internal oversampling, which it doesn’t.
If you can see the meter’s red light going on these are not always “overs”, but the digital signal just hitting 0dBfs, full scale.
Quite common with contemporary recordings.
6 (edited by N00b 2021-02-17 13:37:13)
OP posted:
so I deduced the amp is indeed an integrated one. wink
For the calculator, it's just to translate the Volt sensitivity of the amp into the dBu of the RME, no need to be an engineer to understand that wink
And for the overs, I don't want to make things more complicated than they are and I would stand with my post:
Oh sorry, yeah it is indeed an integrated amp, NAD C 315BEE. So quality-wise, does it matter which unit I use to control the volume? Seems like it doesn't, just which one I want to use?
If you use the NAD to handle the volume, you won't be able to use some features of the RME (like the clever volume setting with Auto-Vol-Ref and the very useful dynamic loudness).
Got it, thanks for the clarification
10 (edited by KaiS 2021-02-17 19:00:31)
You still have both options, “CASE 1” and “CASE 2“, from the linked setup guide.
It’s more a matter of convenience which one to choose.
Sound quality is excellent both ways.
I.e., if you have other sources like a vinyl disc player or radio tuner etc. connected, it’s better to use the NAD’s volume control (CASE 1) and adjust the ADI-2 to a reference level that about matches when switching around sources.
If ADI-2 is your only source, the NAD can be use similar to a normal power amp - in fact it’s technically not different, except for it’s switching matrix.
This would be CASE 2.
