Topic: OctaMic v1 stop working
Hello, yesterday during a recording session my OctaMic v1 stop working, symptoms are:
- Lost sync with ADAT (as master) with my audiocard (slave), if i play one song, audio work for 1 sec. than stop for 1 sec. repetitively
- All 8 pre channel stop working, if i connect microphone and raise gain at maximum, not have even minimum signal (it happens to all 8 channel)
- Phantom power not work anymore on all 8 channel
Additional info:
- Power supply "seems" work, have green light on and the OctaMic it turn on, 48V orange LED work when i push the button (but not 48V is provided through XLR), reset green LED work if i push the button for some seconds, output switch green LED (Hi Gain, +4 dBu, -10 dBV) work. So only all LED of the unit work.
- I live in Italy
Thanks in advance for help
Re: OctaMic v1 stop working
Power supply "seems" work - partially, half way broken.
Time for service overhaul I guess.
MIDIWARE SRL
Via Cassia, 1081 00189
Roma
ITALY
0039-06-30363456
supporto@midiware.com
www.midiware.com
If I 100% sure the power supply is partially broken i can buy new one without send the unit for service..
This mail not work anymore:
4 (edited by waedi 2021-06-05 15:57:32)
No one can say 100% what is up with your device by reading over the internet.
The service point can do a proper inspection and offer a repair if needed.
Replacing the internal power unit is not a bad idea in this case with the scenario described by you.
And as you can do it at home the risk is not so big.
May you try this email : info@midiware.com
The power supply is external not internal
Thank you for the new email
