Topic: No TotalMix FX on Windows 10
Greetings.
I did a search, but no results.  I am on Windows 10, and can't install TotalMix FX.  I've installed the USB and Thunderbolt (driver_madiface_win_09673) , and no TotalMix.  I feel like an idiot asking, but how does one install TotalMix FX for Windows?  I can't locate a TotalMIx install/download on the RME website.
Thanks in advance for your help.
-09
Re: No TotalMix FX on Windows 10
Its installed by each driver installation, maybe caused be Windows, see here what might solve the issue
https://www.forum.rme-audio.de/viewtopic.php?id=27331
What Windows version do you have ? 1803 or 1709 still ?
What does "can't install" refer to? Is the file present in c:\windows\system32?
Windows 10 pro v.1803.  Lightbox, thank you for the video.  I followed it, and did see the TotalMix options for the tray.  I turned those on, still no TM.  Rebooted.  Still no TM.  No exe in C:\Windows\System32.   I've installed the driver packages as sent to me by Joost at RME.  Twice.  Rebooted after each.  Nothing.
Thanks again for any help.
-09
Thanks, but there is no TM option on the startup tab.  Win 10 pro 1803 here.
6 (edited by Omicron9 2018-08-24 16:43:40)
I can run the installers successfully.  However, nothing is present in the Sys32 folder.   I really need to get this working.
Thanks again for everyone's help.
C:\Windows\System32\TotalMixFX.exe not there ?!
No.  I have a screenshot for proof, but can't see how to attach or include it here.
9
Please post the log file DPINST.LOG from C:\Windows. It includes information if something was skipped during installation.
Will do; is on my other computer, but will get it and post it.  Thank you.
I have exatelly the same problem - no totalmix in win/system32 folder.
the DPINST.log is listed below.
It seems, that everything should be ok, but it is not.
INFO:   ****************************************
INFO:   06/09/2021 12:22:03
INFO:   Product Version 2.1.0.0.
INFO:   Version: 6.0.6000
INFO:   Platform ID: 2 (NT)
INFO:   Service Pack: 0.0
INFO:   Suite: 0x0100, Product Type: 1
INFO:   Architecture: AMD64.
INFO:   Interactive Windows Station
INFO:   Command Line: 'C:\Users\tkacz\AppData\Local\Temp\rme\dpinst64.exe'
INFO:   DPInst is not multi-lingual.
INFO:   Current working directory: 'C:\Users\tkacz\AppData\Local\Temp\rme'
INFO:   Running on path 'C:\Users\tkacz\AppData\Local\Temp\rme'
INFO:   User UI Language is 0x415.
INFO:   Install option set: Force install if driver is not better.
INFO:   Install option set: uninstall will be set to delete driver binaries.
INFO:   Found driver package: 'C:\Users\tkacz\AppData\Local\Temp\rme\fireface_usb.inf'.
INFO:   Preinstalling 'c:\users\tkacz\appdata\local\temp\rme\fireface_usb.inf' ...
INFO:   ENTER:  DriverPackagePreinstallW
INFO:   Driver package is already preinstalled 'c:\users\tkacz\appdata\local\temp\rme\fireface_usb.inf'.
SUCCESS:c:\users\tkacz\appdata\local\temp\rme\fireface_usb.inf is preinstalled.
INFO:   RETURN: DriverPackagePreinstallW  (0xB7)
INFO:   ENTER:  DriverPackageGetPathW
INFO:   RETURN: DriverPackageGetPathW  (0x0)
INFO:   ENTER:  DriverPackageInstallW
INFO:   Installing INF file 'c:\users\tkacz\appdata\local\temp\rme\fireface_usb.inf' (Plug and Play).
INFO:   Looking for Model Section [Devices.NTAMD64]...
INFO:   Installing devices with Id "USB\VID_0424&PID_3FC5&REV_0001" using INF "C:\WINDOWS\System32\DriverStore\FileRepository\fireface_usb.inf_amd64_bcb5f43ac8b263be\fireface_usb.inf".
INFO:   Will force install because driver is not better and force flag is set.
INFO:   ENTER UpdateDriverForPlugAndPlayDevices...
SUCCESS:RETURN UpdateDriverForPlugAndPlayDevices.
INFO:   Installation was successful.
SUCCESS:Install completed
INFO:   RETURN: DriverPackageInstallW  (0x0)
INFO:   Successfull installation of 'c:\users\tkacz\appdata\local\temp\rme\fireface_usb.inf'.
INFO:   Machine will have to be rebooted to complete installation.
INFO:   Returning with code 0x40000001
INFO:   06/09/2021 12:22:32
12 (edited by mkok 2021-06-11 15:30:35)
What if you do a search on your PC for the file. Can you find it then? How about downloading the beta version from the forum and manually putting it in place. It’s the sticky subject at the top of the TotalMix forum.
13
No error in log and file not found means most probably you have an Antivirus solution installed that removed the file. The Settings dialog is in \System32, and working?
