Topic: MADIface Pro box
any MADIface Pro users around here who managed to make the mains connection cable of the small power supply fit into the MADIface Pro box...?
It's a pity it is delivered separately and doesn't have room in the box - contrary to the power supply itself.
I even fail if I remove the MIDI cable (which I do not need).
Huge problems, indeed...
Ulrich
Re: MADIface Pro box
Won't fit, sorry.
3 (edited by hardyroede 2021-06-27 20:20:32)
Ulrich wrote:
Slightly OT and/or maybe not your use case, but you do know that the device works on USB bus power alone as long as you do not use MADI?
MADIface(s) Pro, UFX+, MADI Router
Mac mini Intel, iPad Air 2020
ProTools, Hindenburg
True, I need MADI...
How about cutting a square piece out of the bottom inside ?
Isn't there an empty space ?
I will check this, receiving the NTcardbus-X this week and would like to have it inside the box.
