There is no (analog) pre section in ADI-2 DAC.
• Disable all digital DSP functions that you don‘t want to use:
Equalizer, Bass/Treble, Loudness, Phase etc.
• Set Auto Reference Level to “off”.
• Set Volume to 0 dB.
• Select the Reference Level that fits best to your other sources on your preamp, like CD player, Tuner, Vinyl disc player etc.
• Choose the DA filter that sounds best to you (LD Sharp is default).
Now ADI-2 DAC behaves like a normal DAC without DSP extras.
Some of the settings above are factory default, but it doesn’t hurt to go through the list.
