Topic: I need to duplicate my UCX II direct mic input. [Solved]
I bought the RME Fireface UCX II interface. (LOVE IT!)
I bought mic splitter hardware that blocks the phantom power from one input so my mic only gets phantom power from one input.
It is a passive box that has one XLR mic input and two XLR mic outputs and accepts phantom power from only one input and blocks the other phantom power so the mic only gets phantom power from one source but still outputs two sources..
Then I get two identical mic signals, one that I can loop to the UCX II output one (or plug directly into my streaming cpu) and the other that I can send into my DAW through the UCX II input 1.
I am wondering if there is a way that I can split input one within the box so a direct signal will go into my DAW and another direct signal will go to output 1 simultaneously?
