Topic: Utilizing the Babyface Pro as a Studio Monitor Controller
Appreciate any tips on setting up my Babyface Pro to switch between 3 different speaker sources for AB/referencing mixes etc.. or will I need to get seperate monitor controller/switcher to achieve this?
I'm using Babyface Pro with a Macbook Pro running Logic Pro. Also have an ADA8200 interface (w/ 8 x  optical In/Outs) to utilize if that would be of use in this situation.
Thanks in advance for your input.
2 (edited by MetalHeadKeys 2022-03-25 04:41:10)
Re: Utilizing the Babyface Pro as a Studio Monitor Controller
Hello!
I guess that you, allready, are using two ADAT cables to connect the ADA8200 to the BF Pro.
Well, there are three ways you could set this up!
1st
- You can connect the monitors you know and use the most, to the XLR Outs of the BF Pro.
- Then, connect the other two pairs to the Analog Outs of the Behringer.
- Create and save 3 Snapshots(in TMFX) with the routing you want, outputting to the respective pair of monitors! (one for each pair)
Now, you can change Snapshots for A/B/C-ing
2nd
- Same as 1st.
- Connect another pair to the Phones Output via a "TRS to 2 TS" Y-cable. This is an un-balanced connection!
If you keep the cable away from power cables, you won't have any noise isues. Also, match the level with the XLR Outputs!
Connect the 3rd pair to the Analog Outs of the Behringer.
- Same as 1st.
3rd
- Connect all three pairs to the Behringer and use the BF Pro 's Phones Output for your headphones!
Also, in TMFX Preferences Menu, under "Snapshots" section, you can set "Do not Load" to "Control Room Settings".
This way your Control Room Settings won't change as you change snapshots, and you can have the levels of your monitors saved with each Snapshot!
If you 'd ask me, I would go with the 1st way!
Hope this covers everything!
Hey this is a brilliant response. Sincerely appreciate you taking the time to go into that kind of detail.. such a great help!
This will give me an opportunity to get my hands dirty with the The TMFX routing & snapshots, something I haven't really utilized at this level. Up until now I've been using my main set of monitors via the XLR Outs & my second pair via the Phones output (which can be a bit of a pain if you want a seperate headphone level at the same time). I also have a 3rd speaker I'd like to throw into the setup as additional reference.
With Thanks
You 're welcome!!
Glad to be of help!!
TMFX is a breeze! It can, literally, untie hands in terms of workflow!
