Topic: Level meter in dBu ADI-2 DAC FS setup
Hi.
I have tried to setup the Level meter from dBr to dBu via: SETUP - Options - Display - Horizontal Meter - Post FX dBu, without any success. Please, any further input would be vey much appreciated.
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → Level meter in dBu ADI-2 DAC FS setup
Hi.
Screenshot please, what meter ? Whats missing where ?
If Windows, use Greenshot tool, there you can add e.g. text and arrows to the screenshot.
You can also refer to a manual page to make clear what documented feature you are having problems with.
Which firmware version ? Please a real number that you see in the display during power-up, not "latest".
Thanks.
Looks like his unit at Auto Ref set to on. The dBr will change to dB when Auto Ref is set to off.
Yup, I wanted to be sure what display exactly he means.
Hi.
At the ADI-2 Pro it works here as intended, firmware V.113.
Checked with a voltmeter, displayed values are correct for:
• PH3/4,
• Main out 1/2 back XLR,
• back TRS up to +19 dBu.
• PH1/2 output is 3 dB hotter than the dBu meter shows.
