Topic: is the ADI-2 Pro really 32-bit through the entire signal path?
I have read that many 32-bit DACs actually truncate to 24 bit within the DAC chip before reaching the Converter itself.
is this also the case with the ADI-2 Pro fs?
2 (edited by KaiS 2022-07-26 14:11:18)
Re: is the ADI-2 Pro really 32-bit through the entire signal path?
No, ADI-2 internally it‘s 42 bit, 3 bits of which are used for 24 dB internal level headroom.
Read ADI-2‘s manual page 66 (DAC) 93 (Pro), last line:
RME's digital volume control in 42 bit TotalMix technology avoids all the disadvantages of analog level control via pots, is easy to use, offers reproducible settings, and the highest sound quality.
A 24 bit truncation in the DAC chip would not allow the clean performance shown in the measurements on the same page - no distortions at -93.8 dB volume.
At -93.8 dB attenuation a 24 bit signal would show ca. 0.5% or -46 dB distortion relative to signal level, or -150 dB absolute.
The chart reaches down to -190 dB.
3
Tales from the past....
4 (edited by hasan.ay386 2022-07-27 09:48:43)
Wow! Thanks
so the signal path would be like this?
24bit file → 42 bit internal volume control → 32 bit DAC
whatever file -> 32 bit USB interface / 24 bit digital interface -> (optional 32 bit SRC) -> 42 bit DSP -> 32bit DAC.
Small correction - the SRC is 24 bit, and gets fed only 24 bit (via SPDIDF/AES/ADAT).
MC is always correct. I searched AK4127VF's datasheet from digikey (https://www.digikey.com/en/products/det … VF/2538694), whose download button gives what is actually 4137's datasheet.  -_-
