Topic: IEM Power
I need some clarification, as I've never had to do this level of research for a good quality DAC/AMP combo for IEMs.
I am in the middle of purchasing 64 Audio Fourte Blanc. https://www.64audio.com/collections/uni … urte-blanc
The specs say that it requires 10 Ohms power. For the ADI-2 DAC FS, it says IEM max power is 8 Ohms. Though, when reading manual it says:
"Maximum output level is -3 dBu, equalling 0.55 Vrms. The noise floor at extremely low -121 dBu(A) stays inaudible even with the most sensitive In-Ears. At full output level and a load of 16 Ohms, distortion is lower than -110 dB or 0.00039 %."
Will the ADI-2 DAC FS power these IEMs without issue?
My second question: these IEMs come with a balanced 4.4mm cable. Am I correct in presuming the Phones and IEM outputs are on the ADI-2 DAC FS unbalanced? (I realize I would need a 3.5mm (M) to 4.4mm (F) conversation cable regardless). If that is the case, is there a recommended piece of hardware to convert the unbalanced output signal to balanced? The IEMs do also come with a TRS 3.5mm cable, so, it's not the end of the world if I cannot use 4.4mm immediately with this DAC/AMP combo.
Thanks in advance.
MB
