1 (edited by GeometryGod 2022-12-18 01:23:22)
Topic: ADI-2/4 Pro Routing Question
I just recently purchased the newly released ADI-2/4 Pro (awaiting delivery) and have a question about routing.
I have a UCX II I use with TotalMix FX. I will be sending audio to the ADI-2/4 digitally via my UCX II for headphone + speaker monitoring.
I am looking to plug speakers out from the ADI-2/4 Pro (ch 1/2 - rear), and headphones out from the ADI-2/4 Pro (ch 3/4 - front).
Is there any way I can independently control the output volume of both 1/2 and 3/4 via totalmix so I can control the volume of both speakers and headphones? Or would I need to do this via the front panel of my ADI-2/4?
I looked in the downloadable manual for the ADI-2/4 but was a bit confused about routing in this scenario. Any help is greatly appreciated.
Thank you!
Re: ADI-2/4 Pro Routing Question
Using TM would require to use two digital ports, like AES and SPDIF optical, from UCX II to ADI-2, activate Multichannel mode in the ADI and set the sources for its outputs accordingly. Looking at the block diagrams you will find 3 modes allowing this setup.
3 (edited by ramses 2022-12-18 12:09:44)
Hi GeometryGod,
welcome to the RME user forum.
In my blog I described such a setup, as mentioned by Matthias, how to select the output of an ADI-2 Pro by sending audio to either the AES or ADAT input of that device.
https://www.tonstudio-forum.de/blog/Ent … ort-DE-EN/
https://www.tonstudio-forum.de/attachment/1963-01a-overview-adi-2-pro-totalmix-fx-arc-usb-jpg/
The relevant steps of configuration for the ADI-2 Pro
Setup -> Options -> Device Mode / DSD -> Basic Mode: AD/DA
Setup -> Options -> Device Mode / DSD -> CC-Mode: Multichannel
I/O -> Main Output 1/2 -> AD/DA Source: AES
I/O -> Phones Out 3/4  -> AD/DA Source: SPDIF
Store settings in one of the presets.
Certainly, works for the ADI-2/4 Pro SE as well.
Personally, I don't use this type of setup anymore because I don't need to switch between active monitors and headphones that often. So, it turned out to be more practical to simply remapping a button on the ADI-2 Pro for switching.
At the end of the day, it also saves a digital input and snapshot space in TotalMix FX that I'd rather use for other things.
I've described how this works with key re-mapping, and what other re-mappings have proven useful to me, in this article:
Thank you Ramses! This is an absolute game changer!
