Topic: Error signal when Log Analog signal
When i ADC analog signal with output impedance of about 32ohm the received digital signal is cut off (1 positive half cycle)
How to log the signal correctly
Details in attached file
https://drive.google.com/file/d/1tKSnrf … sp=sharing
Re: Error signal when Log Analog signal
On ADI-2, try one step higher Reference Level.
I increased the ref level to 24 dBu, however the signal is still clipping at positive cycle (not happening with negative cycle)
4 (edited by KaiS 2023-01-16 07:37:06)
Try a signal from a completely different source.
Connect ADI-2 Pro’s output to it’s input and play a sine wave.
Check left and right input seperately.
i use signal generator and adc log is correct
https://drive.google.com/file/d/1TPsndB … sp=sharing
6 (edited by KaiS 2023-01-16 10:58:47)
So ADI-2 Pro is OK then, right?!
In this case please change the title, add “SOLVED”, to help other readers understand.
